3.9K or 100K resistor in place of KNOCK SENSOR?
Old Nov 2, 2001 | 12:43 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I have an 89 305, TPI, 5 spd, 3.08 rear.
I do not know the number of my ECM. For that car should I be using 3.9k or 100k resistor?
I do not want ot blow anything up.
Does anybody know?
Old Nov 2, 2001 | 07:13 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The only way to really find out is to measure it yourself. Buy or borrow a DVM, lay under the pass. side of the car, unplug the knock sensor connector, stick one probe into the middle of the sensor, touch the other probe to your engine block, look at DVM, observe reading (you might have to change the ohm scale to read it right). Shouldn't take more than 5 minutes. Oh, you'll need to jack up your car or drive the front up on jackstands.
Greg Westphal
'87 IROC 355TPI/A4
Old Nov 2, 2001 | 08:34 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Thanks Greg.
Old Nov 2, 2001 | 10:16 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Or unplug the EST connector, use the manual to figure out which wire goes to the KS and measure between that terminal and ground. A lot easier than jacking the car up!
Old Nov 2, 2001 | 02:44 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
My 86 Vette takes a 3.9K 5 watt resistor and with wire color to splice it into is colored blue.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9, TPIS Long Tube Headers and DynoMax Super Turbos (HATE 'em)
scottmoyer
Sep 7, 2015 07:06 PM
Ironhead38
Sep 7, 2015 02:26 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
masonta
Sep 1, 2015 06:40 PM
