stock 350 injectors
Old Nov 2, 2001 | 02:35 PM
89FormulaL98's Avatar
stock 350 injectors
im planning on building a fairly mild 383, the question is will the stock L98 injectors cut it if i bump up the fuel presure.
if they wont work i need to sell them, 4 out of the 8 have less than 1,000 on them.
Old Nov 4, 2001 | 03:26 AM
FstBrd6point3's Avatar
I am new to the whole high-displacement TPI thing, I used to drive a jap car. . . but my brother has been playing with big engines for a while, and I am building the same motor, he told me I am gunna have to go to at least 24lb/hr injectors over the stock 19's. Jeg's sells a set of accell injectors for $250, but when other comanies sell them for 50 a pop, U kinda need to wonder. I am gunna gunna go with 30lb injectors and a higher flow pump cuz I am getting a nitrous kit in the spring, but 24lb should be good for you if you are going to stay completely self-breathing.
Old Nov 4, 2001 | 09:25 AM
Guest
Guest
Posts: n/a
Depends on how far you want to go with it and how much power you are looking to make. The stock 22's should feed up to 350hp with no problem, beyond that you would need to see if the pulse width is too wide or not.
Old Nov 4, 2001 | 10:00 AM
superstreet's Avatar
22 lb injectors are probably on the "light" side.If you turn up the fuel pressure (increasing the injectors duty cycle)you will shorten its life.Injectors run at 80% duty cycle,it's possible to hold the injector open up to and including 100%,but again,you will shorten its life span.It is better to step up to the next size injector.Here is a formula to figure out injector size. (Engine H.P. X BSFC) divided by (# of injectors X 0.8) NOTE: BSFC=Brake Specific Fuel Consumption.A realistic number for an average street engine is .50 NOTE:0.8 is 80% duty cycle. Hope this helps.
Old Nov 4, 2001 | 11:35 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I'm using LT1 24# injectors on my slightly modified 350 so I would have to say that for the best performance you're going to need something more than 22# injectors for that 383. Depending on how much you plan to mod the 383 you might look into 30# injectors. When in doubt get a scan tool. Start with whatever size injectors like 24# and use a scan tool and you should be able to figure out from there if you are maxing the injectors out.
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.7:1 Compression, Stock TPI ported, 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech hot coil.
Old Nov 4, 2001 | 02:09 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If this is a street car, the 22lbs injectors will work fine. If you're going to race it a lot, forget them and get 24lbs. I found with my 350 the 22lbs were on the very edge, so I got 24lbs.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
MustangBeater20
Oct 29, 2022 09:20 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
NWAsonoma
Aug 18, 2015 05:45 PM
