Runs open loop all the time, even after replacing o2 sensor
Old Nov 3, 2001 | 02:18 AM
TPortFormula's Avatar
Car: 1991 Pontiac Firebird Formula
Transmission: a crappie 700-R4
My check engine light has been on for the longest time. i scanned it and the computer is throwing the open loop code. i can't understand why its doing this, even after i replaced the 02 sensor. it also idles choppy and rough in cold starts. Need help please!!!
Old Nov 3, 2001 | 11:16 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Check your ECM temp sensor, sounds like that would do it. its on the front of your TPI base.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera
83 Camaro
83 T/A
Old Nov 3, 2001 | 06:31 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
if it's in open loop there's something not right, a sensor out of range. with the Scanner find either another code in there, or the sensors related to the closed loop status.
ie.
o2s
CTC
MAP
if one's out of range for a period of time it may not trip a particular sensor code, but the computer will time out, not go into closed loop and send a code.
It's always SOMETHING
Old Nov 3, 2001 | 08:16 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
hey Pk, u dont have a scanner do u? You know i'm still havin the same problem with the freakin car staying in open loop, its freakin pissing me off!!!! if u have a scanner i'm driving down and stealing it
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Nov 3, 2001 | 08:17 PM
fly89gta's Avatar
Car: 2018 Camaro SS
wait something just hit me, why is PK browsing the TPI boards? is someone ditching that carb on the 355?
Old Nov 4, 2001 | 06:48 PM
mckenzie's Avatar
Hello, check your wires from o2 sensor to ecm. i've seen bad ecm's not allowing closed loop. best of luck, tom
86 iroc 305tpi auto. mild cam
HoosierinWA
Oct 7, 2015 10:15 AM
Giocio
Oct 1, 2015 12:20 PM
aaron7
Sep 30, 2015 09:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
