Smog Pump & ECM question
Old Nov 4, 2001 | 11:43 PM
Lane280's Avatar
I resently had to remove the top end of my engine and upon replacing everything I figured I would leave off all the smog pump junk since I dont have to pass emissions where I live. My question is if I just unplug the two connectors from the A.I.R. system will it throw a code, The connectors that I am speaking of are the two that are over the front of the passangers side valve cover. Any help would be greatly appreciated, thanks in advance .. Lane !
89 iroc 5.7 bored .030 over, fully balanced, wisco flat tops, comp cams hyd. roller,adj. fuel pressure regulator, ported plenum, ported heads, modified air box w/ ram air, jet air foil,accel supercoil w/ 8.8 mm wires,ARP bolts,custom chip, griffin radiator, cat. converter test pipe w/ dynomax exhaust, edlebrock headers w/ ceramic coatings, 700r4 w/ many mods. 13.98 @ 103
Old Nov 5, 2001 | 12:06 AM
Guest
Guest
Posts: n/a
The ecm wont care if those are hooked up or not.
Old Nov 5, 2001 | 12:12 AM
Lane280's Avatar
Thanks for the help !!!
italiano67
Dec 11, 2016 09:21 AM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
