Plugs for a stock 350 GTA
Car: Camaro
Engine: 3800
What to get?
Doing a bit of a tune up and gonna replace em. It may not be stock a lot longer, but nothing extreme...no smog, free'r flowing exhuast, small stuff like that... anyone?
<A HREF="http://albums.photopoint.com/j/View?u=1670288&a=13155057&p=47834932&Sequence=0&res=high" TARGET=_blank>1988 2.8L MPFI auto Camaro
</A> (bright red, not pink)
67 Camaro, being rebuilt.
1988 5.7L GTA ---GTA's interior
[This message has been edited by 67 Camaro 88 (edited November 04, 2001).]
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i've had good luck with the AC Delco rapid fires, already pre-gapped for the L98
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Tony
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
<font face="Verdana, Arial" size="2">Originally posted by fly89gta:
</font>
</font>
Car: Camaro
Engine: 3800
When I did a search I saw those (AC rapid) in a few other threads... will likely use those unless someone can prove otherwise on some other ones.. thanx guys
Car: 04 GTO
Transmission: M12 T56
AC R43TS
You're more than welcome to waste all the money you want to on plugs, but a spark is a spark, plug gimmicks are marketing schemes.
Since you said you did a search on plugs, how many 1 and 12 second cars used gimmick plugs? For that matter how many 13 second cars used gimmick plugs? I think that will illustrate the point i'm making... if plugs were really a go fast part, why don't fast cars run gimmick plugs?
NinjaNife
Aug 23, 2015 11:49 AM
