Injectors ????
Old May 17, 2008 | 11:39 PM
19formula30589's Avatar
Car: 89 Formula
Injectors ????
I want to replace the injectors on my 89 305. I kinda asked this question before and i got a general answer to use ford injectors which i plan on doing but looking at the specs the ford ones have slightly different dimensions. Will any ford 19lbs injector work or is there a specific type. Im pretty much asking for the exact injector to get and from where (not ebay) thanks in advance
Old May 18, 2008 | 12:57 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Injectors ????
i have a set of brand new racetronix 19lb's i bought them for my 5.0 boat. never put them in and sold the boat.. my 5.7 takes 22's so they have been in my tool box.. i will sell them for 200.
let ,e know if you want them
t
Old May 20, 2008 | 06:13 PM
aged 86 transam's Avatar
Car: 1986 trans am
Engine: 305 with almost 2000000 on it!!
Transmission: 700 r4
Re: Injectors ????
well mine did come off ebay, i got them from fuel injector connection, i am mostly doing a stock rebuild so they are not uber performance, but check it out, just do your homework
Old May 20, 2008 | 06:17 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Injectors ????
I just put in a set of for 19# design II's, and they're working great. They're slightly shorter than the OEM ones, but they will work fine, as long as you re-use the clips that hold them in.
These are design II's, like the ones i bought:
http://cgi.ebay.com/ebaymotors/89-Mu...m270238078886&
These are design III's, they are slightly better, and will also work:
http://cgi.ebay.com/ebaymotors/Fuel-...m270237593999&
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
