fuel pressure problems
Old May 18, 2008 | 06:38 AM
blackwrestler34's Avatar
Car: 88 Pontiac Trans AM
i just installed a hypertech AFPR and now im not getting no reading from my fuel pressure gauge, fuel is leaking out of AFPR (not sure if this is supposed to happen) and car is running completely horrible. i am completely lost. my gauge does works and is just not giving me a reading . i don't even know where to begin HELP PLEASE!!!!!! did i install wrong or what ?
Old May 18, 2008 | 08:10 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: fuel pressure problems
Well per your discription some thing is wrong. I would start over and follow the instructions. It should not be leaking fuel. I have had the hypertech AFPR for years with no problems & my FP gage works.
Old May 18, 2008 | 10:12 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Does fuel leak out the vacuum line connection when vac line is removed? If so, the diaphram is reptured and will have to be replaced.
Old May 19, 2008 | 09:32 AM
Raiden's Avatar
Fuel should not be coming out of the vacume port off the pressure regulator. Make sure you don't over tighten the AFPR cap, your only supposed to use 13inch/lbs of torque...I learned the hard way! There is a proper sequence to tighten the AFPR cap, it should be in any service manual and I'm certain there's a thread on this site.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
