electric fans
Old Nov 6, 2001 | 08:45 PM
87-5.7iroc-z's Avatar
Car: '87 IROC-Z
Engine: L98 TPI/Possible LS1 swap
electric fans
Mechanic says the secondary is not coming on because the ecm won't ground out. It needs to be replaced. Anyone know better or is he completely right?
87 Iroc-z Black out/Grey in. 350 tuned port. Auto. T-tops.
#3 Earnhardt is #1!!
Old Nov 6, 2001 | 08:54 PM
breathment's Avatar
hmm, i don't know so much about ur ECM, but might wanna check that temp sensor on the drivers side of the block under the exhaust manifold, that is what controls the secondary fan as far as high temp. take the wire off, ground it on something good, and see if that causes it to come on, im pretty sure thats how to test it, i think..
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Nov 7, 2001 | 09:00 AM
Desert86Roc's Avatar
Most secondary fans are not controlled by the ECM. You need to do as the above post suggests...ground the wire that is going the the temperature snap switch in the passenger side head to a ground. The fan should activate (key must be "ON"). If the fan does not activate, either the relay or the motor itself is bad.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] www.MetzlerRacing.com
Best ET @ 1250 ft[*] 15.352 @ 91.215 mph (uncorrected)
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
