lt1 heads
Old Nov 7, 2001 | 11:05 AM
elec87's Avatar
Car: ls1 rx7, 2 99 hugger orange ss cars
Engine: ls1's
Transmission: 6 speed, autos
lt1 heads
Ok I am just curious about the lt1 head and interchangability Will this work on a 327. Is there a special manifold? Do they bolt to the block? I am running a carb setup to. If this will work will I get any realy performance out of them? Or should I just buy a nice set up aftermarkets
Old Nov 7, 2001 | 01:27 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
I'm sure someone will correct me, but NO you can't use them. I believe the block for LT1s is a different block (gen2) vs. gen1 blocks '55 to present. Anyways, yes you would need a special intake for LT1 heads. The coolant flow direction is different as well as the blot pattern. Hopefully someone else will answer better, but there are a lot of problems trying to swap lt1 heads to a 1st gen block.
I do however think there is a carb manifold that bolts up to LT1 heads, so if you could get a whole LT1 long block...
14.62@96mph headers, muffler, chip, ghetto stuff, duct tape
89 GTA 305 TPI 5 speed 3.42 gears
Old Nov 7, 2001 | 03:13 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
you can use them but the cost of preparing them to work will more than enough pay for a good aftermarket set of heads.....
Old Nov 7, 2001 | 03:46 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by PETE:
you can use them but the cost of preparing them to work will more than enough pay for a good aftermarket set of heads.....</font>
exactly
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Redwhisper
Aug 26, 2015 05:02 PM
