pulling more timing than total advance
Old Nov 7, 2001 | 08:51 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
ok mods are in my sig
i did a search but couldn't find where someone posted this before (it might have been on a different board)
but ok the average is Total Timing: 36 Total Knock Retard 46
the worst Total Timing: 40 Total Knock Retard 107
i would just like to know what to check. this was with 87 octane and i am going to put 92 in and run it and see what i get.
could it be from the car running lean because it has the stock fpr in it and is running lean at WOT 10.x a/f ratio
thanks for the help and just post if you need more info
this is using Craig Moates software
thanks
Andrew
Andrew Peery
1987 IROC, 305 TPI, T5
Hooker Competition Ceramic Coated Headers, Custom y-pipe, Cutout, Flowmaster, Ported Plenum
All smog equipment gone and no cat
before headers
192hp and 265tq
15.20 @ 92.5 mph 2.4 60ft
After Headers
14.480 @ 95.01mph 2.194 60ft
With y-pipe
14.43 @ 96
2.16 60ft
with cut-out
14.11 @ 97.7 2.17 60ft
Old Nov 7, 2001 | 09:00 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Maybe i'm wrong, but i don't see any way your ECM is trying to pull 107' of timing out. I think moates software is displying something else, like knock counts or some other factor. I could be wrong, i've never seen his stuff, but i'm pretty sure the ECM would not have any code designed to fire cylinders at BDC
Old Nov 7, 2001 | 10:41 PM
Car: 87 IROC
Transmission: 5spd
thats what i'm wondering. i just don't know i just started using his stuff today but my knock count go up really bad when i accelerate like i get 150+ knock counts when i run about 1/4 mile, i get about 30 when i just rev it to 4k.
thanks
Andrew
Old Nov 8, 2001 | 07:06 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Sounds like your knock retard numbers are high by a factor of 10. You probably need to run 91/92 octane due to the age of your engine, and definitely if you have an aftermarket chip. I couldn't run anything less than high-octane with my 305 engine when I had a Hypercrap chip, or even when I was burning my own chips. You want your base timing to be set at 6 degrees with any aftermarket chip, 8 degrees maximum with a stock chip.
Greg Westphal
'87 IROC 355TPI/A4
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bellez77
Sep 5, 2015 08:39 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
