Can you rebuild using an LS1/LT1 block ?
Old Nov 6, 2001 | 11:22 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Could you use the aluminum LS1/LT1 block when doing a rebuild ? Arent the blocks in our cars steel ? how much does each weigh roughly ?? Sorry i dont know too much about engines yet
Old Nov 6, 2001 | 11:45 PM
Guest
Guest
Posts: n/a
LT1... ummm maybe but certainly not a straight swap.
LS1... ummmmm no. Totally different animal.
Old Nov 6, 2001 | 11:51 PM
BitchinCamaro's Avatar
Like madmax said no chance on the LS1... the LT1 also use a completely different water pump and distibutor mounting, they are also reverse cooling which would probably cause a bunch of headachs... not worth it IMO.
Old Nov 7, 2001 | 12:02 AM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
You can always get an aluminum block that will fit directly. I believe Scoggin Dickey sells them....theyre hella expensive though.
Old Nov 7, 2001 | 09:38 AM
rockind78's Avatar
If you can find it, pick up an issue of Car Craft entitled "everything you always wanted to know about the chevy small block" (or something like that). But just in case you can't I will give you a preview. Assuming you are not swapping parts between the different generation engines, the LT-1 will take a .030" overbore. The cylinder walls aren't thicker for anything else, though LT-1's (generation 2) and '92 and under blocks (generation 1) are cast iron (not steel...steel is an alloy). Also, I believe Pat Musi (could be wrong on the name) did a hop up of an LS-1 (generation 3) and all he could manage as far as an overborebore on the aluminum LS-1 was .010". Reason probably being that the aluminum block utilizes an iron sleeve in the bores. He did stroke that engine though for 381-2 inches. That thing was awesome.
[This message has been edited by rockind78 (edited November 07, 2001).]
Old Nov 8, 2001 | 02:49 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by rockind78:
Also, I believe Pat Musi (could be wrong on the name) did a hop up of an LS-1 (generation 3) and all he could manage as far as an overborebore on the aluminum LS-1 was .010". Reason probably being that the aluminum block utilizes an iron sleeve in the bores. He did stroke that engine though for 381-2 inches. That thing was awesome.</font>
LS1s can be resleeved to allow larger overboring than .010" . Agostino Racing Engines has gotten LS1s out to 430 cubes with resleeving, boring, and off-set grinding the crank.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 8, 2001 | 08:46 AM
rockind78's Avatar
Touche Matt. I forgot about the new Trans Am that GM will never produce with its 421.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Magman
Aug 2, 2016 08:32 PM
RyanJB
Sep 14, 2015 03:39 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
