Roller Rockers
Old Nov 7, 2001 | 05:49 PM
1986CamaroIROC-Z's Avatar
Roller Rockers
I have a 1986 305 TPI camaro, and was wondering if Roller Rockers work with the Hydraulic Flat-Tapper camshaft, or do you need a Hydraulic Roller Cam. If you dont need a roller cam, then what are the best rockers for my car.
Old Nov 7, 2001 | 07:04 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
you are in luck for two reasons yes roller rockers will benefit your engine even though it's a flat tappet design.second since you have the perimiter bolt valve covers your rockers will be substantiially cheaper than the narrow body rocker arms needed for 87 and later cars................
Old Nov 8, 2001 | 04:51 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
The best are comp cam pro magnums. They are steel roller rockers they will out last the aluminum ones. LPE started using these because of durability problems long term on the street.. with the aluminum ones. IM using aluminum on my car but only for a short time so i dont know how they last long term. Ive been told the aluminum ones only last about 30,000 miles.
90 IROC
SuperRamed 406
Trickflow 23* heads
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
