ESC and idle question...
Old Oct 7, 2001 | 03:14 PM
86Z28TPI's Avatar
I rebuilt the valvetrain on my 86 TPI and now with everything back in place the car idles at 500 (instead of 750) and itr REALLY rough. Throttle response insn't what it should be either. My friend told me on an 86 the ESC is like $800!!!! Anyone know better? Anyone know the part #? Does this sound like the ESC? I'm prety sure the MAF is fine. Any help or ideas would be appreciated.
Thanks!
'86 IROC Z28 TPI 305. Modified air box and MAF, K&N filters, Air Foil, SLP headers and exhaust, Comp Cams 1.52 Magnum roller tip rockers and springs, lightweight valves, Accel Super Coil, cap, and wires. Adjustable FPR with rail pressure guage, and tons of elbow grease!
[This message has been edited by 86Z28TPI (edited November 08, 2001).]
Old Oct 10, 2001 | 12:14 PM
86Z28TPI's Avatar
Nobody knows?
Old Oct 10, 2001 | 06:23 PM
JETHROIROC's Avatar
Sounds more like you have set the rockers too tight to me. What makes you think it's the ESC?
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 11, 2001 | 11:32 PM
Guest
Guest
Posts: n/a
Sounds like a vacuum leak to me.
Old Oct 11, 2001 | 11:46 PM
airdeano's Avatar
86z28tpi,
you might want to readjust your valves again.
what did you set your timing at? recheck your
wires for proper firing order. 1 8 4 3 6 5 7 2
if your vavles are set right, timing is 6-10*
and your wires are right. look for that vacuum leak.
airdeano
Old Nov 8, 2001 | 08:53 PM
86Z28TPI's Avatar
Thanks guys. I'll try it!
junior419
Apr 7, 2025 11:35 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
RyanJB
Sep 2, 2015 01:27 PM
