AFPR
Old May 23, 2008 | 07:00 AM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
AFPR
Can i use a stock rebuild kit and get it to work in my AFPR?
Old May 23, 2008 | 09:56 AM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Re: AFPR
Id like to fix it by weekend, and i dont even know what one i have on the car (afpr). So I was going ot buy a new afpr $100.00 but i wouldnt have it till monday
I just want to use the stock FPR diaphram and plunger, but can these be made to work with AFPR?
Mines black, has a nut and a phillips head screw on the top.
Old May 23, 2008 | 12:36 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: AFPR
The Crane AFPR uses a stock FPR diaphragm. It is black and has a nut and screw on top.
http://store.summitracing.com/partde...5&autoview=sku
Old May 23, 2008 | 12:42 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Re: AFPR
I heard that if you put on a AFPR you have to unhook your O2 sensor or else it wont run right because the computer will try to compensate for it! is this true?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
