injector part no
Old Nov 4, 2001 | 12:08 AM
pontiacpete's Avatar
injector part no
hi could anyone tell me if bosch injector part number 0280150991 work with the tpi 350 ci application i know they flow 24lbs i just want to be 100% sure before ordering new injectors . i hope someone can help me out bye
Old Nov 7, 2001 | 09:23 AM
Desert86Roc's Avatar
You can save yourself some money by going with some Ford SVO 24lb injectors. About $200 less than a set of stock Bosch injectors.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] www.MetzlerRacing.com
Best ET @ 1250 ft[*] 15.352 @ 91.215 mph (uncorrected)
Old Nov 8, 2001 | 10:12 PM
airdeano's Avatar
ditto,
the svo 24# injectors are rated @ 37psi
as the bosch are rated 45psi fuel pressure.
some of the injector models do have different
spray patterns... stream, fan, and mist.
mist is more desirable, then fan. the streams
are for hi flow and fabbed injection methods.
airdeano
Old Nov 9, 2001 | 05:49 PM
thanks for info i think i will go for the stock 22lbs injectors since my 350 engine is gutless
twest2k2
Aug 24, 2015 11:26 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
tmellott89
Aug 16, 2015 02:58 PM
1nastygta
Aug 8, 2015 07:38 PM
