car turns over but will not start !!
Old Nov 8, 2001 | 04:37 PM
ScreaminDeamin85Z's Avatar
ok i swapped the 305 in my 89 out for the engine in my sig, while also adding the 6 speed. when i pulled out the 305 it was running just fine. i hooked everything up electronically and set it to TDC, brand new plugs,double checked firing order on cap. i have fuel, spark, and compression...now why wont it run? how much should it be advanced/retarded? all it does is trun over. it did back fire once when i had it really retarded but nothing else. i have asked a lot of people that i know at shops and no one seems to be able to help so far. can you?
Brandon
"ScreaminDeamin 360"
1989 IROC 350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
T-56 ,McLeod clutch, LT4 PP
http://ScreaminDeamin.cz28.com
Old Nov 8, 2001 | 04:50 PM
Ken88GTA's Avatar
Have you checked the distributor to see if it's off a tooth or maybe even 180 degrees out? Had that problem with a rebuilt motor once. Also, are you sure the injectors are firing, what is your fuel pressure? Still, it sounds like distributor is problem.
Good Luck,
Ken
Old Nov 8, 2001 | 05:04 PM
yes i have checked to see if its 180 out, it wasnt. yes theinjectors are firing because when i double checked the compression stroke the #1 plug has gas on it. fuel pressure is about 50 psi or so. the distributor is sitting down on the intake like it is suppose to be and i turned the cap to point #1 plug wire at TDC.
Old Nov 8, 2001 | 10:34 PM
airdeano's Avatar
sc85z,
id consult the GM service manual for a:
cranks, no start flow chart. youve covered
most of the primary bases.
TPS voltage 2.5v or less.. flood condition
CTS -40* making the ECM think is -40* and
plastering the cylinder with fuel.
turn the FP down to 38# once it starts
turn it up.
airdeano
Old Nov 8, 2001 | 11:02 PM
my friend just toldme earlier that my CTS may be bad and causing it to flood the cyl. so i will try a new one tomorrow and see what if that is it.
Old Nov 9, 2001 | 04:14 PM
well i changed the CTS and that wasnt it. i went ahead and checked the distributor one more time and it is still potining to TDC when i turn it over to the compress stroke on #1 cyl. this is by far the most trouble i have ever had getting my car to start, even when the motor was "brand new" it wasnt this hard. i have no clue what to do about this.
Old Nov 9, 2001 | 10:14 PM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
Brandon,
Check your mail. I have an idea
1990 RS
V8/A4
White/Primer ....Project in the works
1998 Z28
M6/!cags
MTI lid w/k&n
Magnaflow catback
HPP
Underdrive pulley
78 Chevy Fullsize
355 11:0:1
Trickflows, 282/282 .580/.580,, supercomps,torquer, holley 700 DP
Big Bad Sleeper
**Previous Rides**
1990 RS
1985 Berlinetta
Steven 86IROC-Z
May 24, 2026 04:52 AM
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
