Edelbrock TPI Base porting for good heads...
Old Dec 2, 2010 | 05:42 PM
  #51
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Edelbrock TPI Base porting for good heads...
Bringing this post up to date
Old Dec 5, 2010 | 10:30 PM
  #52
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
355tip without flowing your piece youll never know what its really doing and where. Its money well spent and can answer some unknowns.
Youd pay to get your heads flowed...find what an exhaust system would flow so why not the intake. Food for thought.
Trying to get an accel base I just finished flowed. It will be bolted to a set of new 195 AFR street heads which seems to be the most popular one guys are using. Guy it belongs to isnt interested in the #s but I am and bet there are others. heck someones gotta spend it.
information costs $ to get sometimes but is priceless sometimes.
Like the pics of that ported Eddy. looks like a LOT was removed from the roof, is there enough material in there to do through the whole port like that? didnt get that impression from the accel but again dont have a sonic tester either.
Dear Santa, Ive totally sucked this year but want one anyway
Old Dec 5, 2010 | 10:47 PM
  #53
VincentZ28's Avatar
With that type of work, the accel flowed328-330. The Edelbrock flowed 315-320. It has been done.
Old Dec 6, 2010 | 10:36 AM
  #54
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Did you notice how much weld was applied to the roof before the porting began?
The rest of the port is large enough with a little help that is.
Old Dec 6, 2010 | 11:03 AM
  #55
Dyno Don's Avatar
Here is what the dyno graph looks like after porting this way.
Attached Thumbnails Edelbrock TPI Base porting for good heads...-pats-dyno.jpg
Old Dec 6, 2010 | 11:10 AM
  #56
Dyno Don's Avatar
Here is what one of the lastest looks like.
Attached Thumbnails Edelbrock TPI Base porting for good heads...-jon91z28.jpg
Old Dec 6, 2010 | 12:45 PM
  #57
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
By adding the weld on top it not only allows a taller port height but you can "arch" the port to match up to the head instead of being at an awkward angle. This will promote better flow into the head. I am about ready to take an Accel manifold to the welding shop to do just that. With the shorter Bosch lll injectors versus the factory ones I can raise the injector port without losing anything. Win win all the way around.
Old Dec 6, 2010 | 01:06 PM
  #58
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Very impressed with those graphs...
I have a supercharged 355. I'm looking at doing something like this while the car is down. Don, can you get me a Edelbrock base ported to me in NC from Jerry?
If so, how much. If it matters I have siamesed SLP runners gasket matched and a ported plenium(58mm tb and openings) with siamesed holes on it as well...
Old Dec 6, 2010 | 02:48 PM
  #59
Dyno Don's Avatar
Nope, Jerry doesn't do them now, talk to Dr. J's performance.com he does them, maybe $625 with welding. (to your manifold)
Old Dec 6, 2010 | 03:12 PM
  #60
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
when you say raise the injector ports do you mean you have to weld in bungs to hold the injectors?
does the $625 port job and getting 320-330cfm out of an accel base mean they need to have the injector bungs welded in also or just have the roof welded and ported?
Old Dec 6, 2010 | 03:38 PM
  #61
Car: 1989 GTA
Engine: 369 TPI
I don't think Dr J welded any injector bungs. So I would say no in your case. I am shooting for over 550hp at the motor and need some cross sectional area.
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
89-S-dime
Aug 12, 2015 11:57 AM
