Edelbrock TPI Base porting for good heads...
Old May 26, 2008 | 03:15 AM
JERRYWHO's Avatar
Its time to make a TPI base that will support a good 190cc or larger heads. A stock Edelbrock base has a Intake min. cross sectional area of 1.70 square inches ( 1.600 tall X 1.100 wide ) about the same size as stock L98 aluminum heads. I need about 2.4 or more CSA for my project, so lets start the project. The first thing to do is get a new base and thats done.
Jerry
Attached Thumbnails Edelbrock TPI Base porting for good heads...-mvc-004f.jpg   Edelbrock TPI Base porting for good heads...-mvc-010f.jpg
Old May 26, 2008 | 03:50 AM
JERRYWHO's Avatar
Re: Edelbrock TPI Base porting for good heads...
My heads are ported 215 cc Dart Pro 1s that have 1.200 wide X 2.100 tall ports, so this is the size i need to shoot for. The 1.200 wide will be easy and the only area that needs help is on each side by the fuel injector boss. Now getting from 1.600 to 2.100 tall is a lot harder. The fuel injector to the port floor is 1.850 so it's time to move the injector up .250 to get the 2.100 I need. A picture of the new injector mounting fittings.
Jerry
Attached Thumbnails Edelbrock TPI Base porting for good heads...-mvc-012f.jpg
Old May 26, 2008 | 04:14 AM
JERRYWHO's Avatar
I had to offset bore the stock injector boss out to fit the new injector fitting. This will move the injector up and outward need to keep the stock injector angle into the stock fuel rail when I move the fuel rails up .250. One good byproduct of this is now the injector location is more like a LSX type engine and points the spray more at the back of the intake valve.
Jerry
Attached Thumbnails Edelbrock TPI Base porting for good heads...-mvc-016f.jpg
Old May 26, 2008 | 04:25 AM
JERRYWHO's Avatar
A picture of the fittings ready to be pressed in and installed. Now time to fire up the welder and weld them in place and fill the roof area that needs to be moved.
Jerry
Attached Thumbnails Edelbrock TPI Base porting for good heads...-mvc-020f.jpg   Edelbrock TPI Base porting for good heads...-mvc-022f.jpg
Old May 26, 2008 | 03:17 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
Nice lathe work Jerry! Its times like this, me seeing another person fabbing up a hotrod part. Wished I could be a ghost in the corner just so I could get a whiff of the coolant, and aluminum as it was being worked into a piece of art.
Old May 26, 2008 | 11:31 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Looking good. Go Jerry Go. I have no doubt we will see some amazing numbers comming out of Jerry's motor with this intake system.
Old May 27, 2008 | 12:17 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Is this the type of moddified bases you cali guys have been running that flow 300 cfm or so?
nice to see some pics of them and the how to on making them. very nice
Old May 27, 2008 | 02:47 AM
JERRYWHO's Avatar
The old 300 cfm base is 1.850 tall ports and the injectors in the stock location, this base is 2.150 tall ports and relocated injectors.
I have welded the roof and injector area and have the first couple mill steps setup. Sorry about the dark pictures the flash is dead on my camera.
Jerry
Attached Thumbnails Edelbrock TPI Base porting for good heads...-mvc-025f.jpg   Edelbrock TPI Base porting for good heads...-mvc-029f.jpg
Old May 27, 2008 | 09:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
wow, these are the bases that aftermarket companies SHOULD make. that is awesome! should flow something incredible
There is no problems with the injectors moved up .250 is there? i guess that aint to high but could make a difference with how fuel rails fit under the runners i guess
Old May 27, 2008 | 11:44 AM
tpi user's Avatar
this should be some good reading. i hope you post pics of every step of the way.are you lookin 4 the same results as 89gta?
Old May 27, 2008 | 12:24 PM
Car: 1989 GTA
Engine: 369 TPI
Orr89RocZ. Yes to answer your question. However Jerry is taking it one step further by raising the injectors with the bungs. There is room to raise the injectors somewhat before the fuel rail hits.
On my installation I had to have the fuel rails machined some in order to clear the runners. It may not show up that clear but Jerry is also reshaping the angle of the intake manifold entry into the head. He is performing two operations in one. Opening up the port to the proper cross sectional area and reshaping the entry angle.
I might add that Jerry has been an inspiration to us here locally.
Old May 27, 2008 | 12:34 PM
tpi user's Avatar
is jerry using the slp runners like 89 gta ,i know gta used first lower intake
Old May 28, 2008 | 12:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Jerry is using an Accel Super Ram as far as I know.
Old Jun 9, 2008 | 12:54 AM
JERRYWHO's Avatar
With a Super ram you can go .250 with no problem. TPIS long tubes are also no problem. Now SLP runners make the plenum mount lower then stock and you will have problems with the front fuel crossover hitting the EGR passage on the bottom of the plenum.
I have a Super ram.
Jerry
Old Jun 9, 2008 | 01:09 AM
JERRYWHO's Avatar
Update: Have all the welding done and about 1/4 of the port work done.
Jerry
Old Jun 9, 2008 | 12:14 PM
Car: 1989 GTA
Engine: 369 TPI
"these are the bases that aftermarket companies SHOULD make." Yes it would be no problem for Edelbrock to change their casting. I'm afraid BBK might have missed a good oportunity. Go Jerry Go.
Old Jun 10, 2008 | 10:05 PM
JERRYWHO's Avatar
I'm all for that, this intake will have about 45 hrs in it when done.
I have the roof angle change down to 10 degrees from the factory 26
To show the change in the new intake roof look at the bar stock laying in the ports. The first one is in a stock port, the second is in a ported port and the blue silicone is a trick flow 195 casting. See how much better the new roof will line up to the heads roof. The new roof angle is over 1 inch into the intake, can you say high port TPI.
Jerry
Attached Thumbnails Edelbrock TPI Base porting for good heads...-mvc-010f.jpg
Old Jun 10, 2008 | 10:50 PM
Car: 1989 GTA
Engine: 369 TPI
Looking real good. You have gone from a 1.6" tall port to a 2.15" tall port. That is .55" which is over a 1/2 inch from stock. Yes that is a tall port.
Old Jun 15, 2008 | 08:06 PM
86 IROC's Avatar
Jerry
Thus making it not very cost effective for those of us unable to do the work ourselves. I'm glad you are doing this to show it can be done and will make great power just the same. I look forward to seeing the finished results.
Old Jun 17, 2008 | 12:52 AM
Kevin91Z's Avatar
Jerry is a stickler for details and will spend an hour on a project just to make sure a millimeter of area is 100% correct.
If you arent able to do this yourself, tell the guy porting your intake to concentrate on the area by the injectors. We have found that area to be the smallest cross-section. And then gasket match the ports.
Old Jul 25, 2008 | 11:48 AM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
Found this on the web. Are some castings different than others? I mean, I know that they are not exactly the same, but it says here the Hi-Flo measures 1.88" tall. Could someone please double check on this? Thanks
Stock Base runner ports = 39mm dia.(1195 sq mm) (1.470", 1.697 sq in ) *Measured
Stock Base intake ports = 29mm X 44mm (w X h) (1276 sq mm) (1.73"x1.15", 1.986 sq in ) *Measured
Edelbrock Base runner ports = 41mm dia.(1320 sq mm) (1.609", 2.033 sq in) *Measured
Edelbrock intake ports = 29mm X 48mm (w X h) (1392 sq mm) (1.883"x1.13", 2.138 sq in) *Measured
Ported Edelbrock Base runner ports = 45mm dia.(1590 sq mm) (1.757", 2.425 sq in) *Measured
Ported Edelbrock intake ports = 32mm X 52mm (w X h) (1664 sq mm) (1.26x2.05", 2.583 sq in) *Measured
ZZ4 (Vette L98) intake ports = 31mm X 49mm (w X h) (1519 sq mm) (1.220"x1.929", 2.353 sq in) *Measured
Old Jul 25, 2008 | 07:52 PM
Car: 1989 GTA
Engine: 369 TPI
The problem with those numbers is that they were probably measured at the openings. You will find if you go say and inch or two into the openings(runners or base) that the numbers or cross sectional area is much less. Well under 2 square inches. More like 1.85 or even less in some cases such as the TPI Vortec manifold.
Old Jul 28, 2008 | 10:41 AM
Car: 1991 GTA
I see. I missed that part. I am looking forward to see the final flow numbers. This project is so interesting. Please keep us up to date
Old Aug 5, 2008 | 03:41 PM
Car: 1991 GTA
No news?
Old Jan 15, 2009 | 12:47 PM
Car: 1991 GTA
Flow numbers? Anyone?
Old Jan 15, 2009 | 03:41 PM
Car: 1989 GTA
Engine: 369 TPI
Jerry has been real busy at work and the progress of the intake has slowed down.
Old Jan 17, 2009 | 01:20 AM
Kevin91Z's Avatar
The intake Jerry did for me flowed 310 cfm on one port and 315 cfm on another port.
Old Jan 17, 2009 | 08:28 AM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Do you think an Edelbrock base would be able to cover the old style AFR 210 heads.Thanks
Old Jan 19, 2009 | 12:57 AM
Kevin91Z's Avatar
If they use a 1206 gasket, no I dont think so. I believe the biggest is a 1205 gasket unless you do some major welding and porting.
Old Mar 7, 2010 | 04:42 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
subed to see the finished pics! Sue would be nice to get my hands on a 300+cfm base
Old Mar 7, 2010 | 05:35 PM
Car: 1989 GTA
Engine: 369 TPI
For around $525 you can get your base ported to flow well above 300cfm. Dr. J did an Accel version and it flowed 330cfm. That will support some serious horsepower.
Old Mar 7, 2010 | 05:59 PM
Guest
Guest
Posts: n/a
I have my Edelcrock base ported to a 1206. There was plenty of material on it for sealing. I'll find my pictures and post them up later.
Old Mar 7, 2010 | 06:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
What is the largest port size the base can be ported to without welding/raising the injectors? Do you have flow numbers on that? I never got around to porting the head side runner on my old superram base. I just opened u the runner tube hole size to large tube runners and took it in as far as i could reach.
Old Mar 7, 2010 | 07:33 PM
Car: 1989 GTA
Engine: 369 TPI
I think this is a good time to once again say the Vortec TPI base is the worst flowing after market one out there. We have had a couple seriously worked on with a lot of welding and it is a chore to get 300 cfm out of them. I mean SERIOUSLY worked over. By the way Edelbrock makes all the Vortecs.
The First TPI intake manifold flows 300 cfm out of the box and it only goes up from there. I believe you could get an Accel TPI intake manifold to flow 300 cfm without welding. I'm not sure you can do it with the Edelbrock standard TPI. It would take someone with a flow bench and some judicial grinding.
Old Mar 7, 2010 | 08:16 PM
Car: 92 1500p\u 2wd
Well im runnin an edelbrock base on my truck now but i have 2 SRs that im workin on both with accel bases. One of the bases has been ported some and i think it was done by a pro....you can see the score lines from where they marked out the gaskets. Not sure what size gaskets they ported to but i would like to port that one more since lots of the work is done already. Would 300cfm support a 224-230 .53*s lift 195afr headed 355 motor alright? this is what im workin on. pics of a 300+cfm non-welded base would be perfect if anyone has any!
Old Mar 7, 2010 | 09:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
AFR's only flow 280's cfm so 300 cfm on the manifold is a good starting point to not limit the heads.
Old Mar 7, 2010 | 10:41 PM
Car: 92 1500p\u 2wd
oh well in that case a 285cfm base would be nice haha
whats needs to be done to get one to flow that much? i dont want to pay to have it flow tested so how do i would i know when im close to the 285-300?
Old Mar 8, 2010 | 01:29 PM
Car: 1989 GTA
Engine: 369 TPI
"how do i would i know when im close to the 285-300? "
I would say you need the exit port to the head be at least 2.2 square inches taking the radius into account. This also means the rest of the port back up to the runner inlet needs to be opened up likewise preferably with a taper to at least a 1.75" opening at the runner. I assume you are using the Accel intake manifold.
Old Mar 8, 2010 | 06:41 PM
Car: 92 1500p\u 2wd
Yes Ill be using the accel base!
Old May 11, 2010 | 05:21 PM
galletti's Avatar
Car: 1988 IROC Convertible
MadMax, I'd be very interested in seeing the pics of your ported intake. I just got an Edelbrock base and runners and will match those to their gaskets. I'm working on rebuilding and porting my 416 heads (not looking to spend too much) with LS1 valves. I'm wondering what would be the best gaskets to match my intake to the heads. Any ideas?
Old May 11, 2010 | 08:39 PM
Guest
Guest
Posts: n/a
If I find them, I will post them up for you. They seem to have gone missing at the moment, so I'm going to have to find my backup discs wherever those are packed away.
Old May 11, 2010 | 11:23 PM
  #42
Car: 92 1500p\u 2wd
Jerry
whats needed to weld on a intake base like this? Im having trouble with this part!! need some help please
Old May 12, 2010 | 10:48 AM
  #43
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
ima get my edelbrock tpi base and slp runners welded and ported by dr j soon (thanks 1989gtatransam).... i will have the same excellent flowing tpi system as you southern cali guys....
Old May 21, 2010 | 04:16 PM
  #44
bungo78's Avatar
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
they are pro's!
Old May 22, 2010 | 12:26 AM
  #45
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
is anybody willing to tell how much it costs to get dr. J's to do the full spiel on the intake, runners, plenum and everything to get it into the 300 range? i know it would be subject to change and they say the dual plane intakes start around $525 but I couldn't find anything on TPI.
Old May 22, 2010 | 10:22 AM
  #46
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I haven't had him do anything with runners, but the base work runs $100 for welding and $525 for base porting.
Old May 22, 2010 | 12:33 PM
  #47
Car: 1989 GTA
Engine: 369 TPI
Here is Dr J's web page. Give him a call.
http://www.j-performance.com/index.p...d=16&Itemid=30
Old Sep 17, 2010 | 11:24 PM
  #48
TxTtopZ's Avatar
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
Sweet! Cant wait for an update!
Old Sep 18, 2010 | 11:03 AM
  #49
Dyno Don's Avatar
The Accel that flows 330 is on a '91 Z28 w/auto trans.
It sports a set of out of the box Trick Flow 195's, a stock port matched Super Ram and a Comp 280 XFI.
It put down 351/386 to the rear wheels and ran 110 in the 1/4.
Old Sep 18, 2010 | 11:09 AM
  #50
Dyno Don's Avatar
Double post*****
