hey look, another PCV question!
Old May 26, 2008 | 11:52 AM
mnmattie's Avatar
91 5.0 TPI, there's a PCV on the driver's side valve cover, and on the passenger side there's just a fitting/hose that goes to the intake with no valve. Question is can i replace the fitting/hose on the passenger side with another PCV or does this unvalved fitting/hose have to be unvalved so the whole PCV system can function???
-Mattie
Old May 26, 2008 | 12:13 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Re: hey look, another PCV question!
I was under the impression that one valve cover gets a PCV and the other cover has a breather tube so the oil gasses have a place to go.
Old May 26, 2008 | 01:47 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
the one on the passenger side is the inlet, the pcv valve on the driver side is the outlet. pcv sucks blowby back into the engine, clean air from the passenger side tube replaces the blowby. if you put a pcv valve on both side, you have defeated the purpose of the pcv system.
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
squiggy2
Aug 9, 2015 09:30 PM
