Fuel Pressure Question
Old Nov 13, 2001 | 10:57 AM
MSD tech's Avatar
I have a question about what fuel pressure the factory pump should be able to sustain. I built an adjustable regulator for my 92, I set the pressure at 50 and after 10-15 miles the pump started screaming and the car shut off. Not having any tools, I limped the car home and reajusted it back to stock and all is well for now. I am assuming the pump is just old and not able to keep up. Secondly what aftermarket in tank fuel pumps are you guys using? Are any of them more reliable then the next? If I am changing it I might as well upgrade it. Thanks for any feed back you might offer. I posted this in two forums, I was not sure which to post it in. Sorry.
Joe
[This message has been edited by MSD tech (edited November 13, 2001).]
Old Nov 13, 2001 | 02:09 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Check this out:
https://www.thirdgen.org/messgboard/...ML/000277.html
Ron is the man.
Old Nov 13, 2001 | 02:23 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
hmmm, well the stock pump shouldn't be freaking out over 50 psi. I was running my 305 w/ 56psi for better than half a year and it never complained once, even w/ over 90k on it.
As for a replacement, the wal bro pumps have even highly regarded for years in these parts.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.7 @ 93.6
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Nov 14, 2001 | 11:06 AM
MSD tech's Avatar
Thanks guys. After putting a few miles on it with the pressure back to stock it is lightly acting up. It is hard to start now, the pressure takes a longer to build on the gauge and it has lost power up top. I guess the extra pressure just pushed the pump over the edge and its on its last leg. I am going to order the 255, hell its only a few bucks more them a AC replacement. Guys thanks for the feed back, if you have any ignition questions feel free to ask.
Joe
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
