TPI chasis wiring question
Old Nov 14, 2001 | 11:12 AM
Momar's Avatar
I have an 87 maf tpi setup. I want to convert to speed density. I plan on probably just buying a gm speed density harness. My problem with this is that I need to know what all is different about the chassis harness and if I can just change it to work or if I need one from a tbi car. I know that my spedometer wiring will be different. I have been told that you just dont use the buffer. I would like more information on how to get rid of it. Also I think that I may have read that the aldl connector would be wired different. If any of you know what I need to do to fix any of these problems or know of any other that I will have to deal with pleas help me out.
Ben
Old Nov 14, 2001 | 11:55 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Nuff said.
P.S. You don't need the whole harness to convert to speed density, just need to repin some of the connections and change a few sensors. My first question would be why do you want to convert to speed density?
Greg Westphal
'87 IROC 355TPI/A4
Caspar
Jun 19, 2016 11:19 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
