400ci sb tpi?
Old Nov 14, 2001 | 06:19 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
400ci sb tpi?
will the tpi setup work on a 400 small block?
how about the mini ram?
Old Nov 14, 2001 | 06:40 PM
Desert86Roc's Avatar
Will the stock TPI work on a 400, yes with modifications. Will you see the maximum potential for your engine, No.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] www.MetzlerRacing.com
Best ET @ 1250 ft[*] 15.352 @ 91.215 mph (uncorrected)
Old Nov 14, 2001 | 08:11 PM
BlazinOR's Avatar
I run TPI on my 406...........has a 52mm throttle body........24lb/hr injectors, custom chip and runs like a bat out of hell........
Do I rev it over 5K? No, so might not be able to keep up with the displacement. Mine is in a K5 Blazer - even in the sand no real need to rev it that hi.
'79K5 Blazer with 406TPI
Old Nov 14, 2001 | 10:45 PM
u r sofa king we tah did's Avatar
a 400+ ci motor with stock tpi should be used for just an offroad vehicle that doesnt need to rev high. a 400 with TPI makes massive amounts of torque. great for towing and offroading.
1986Z28OWNER
Dec 13, 2015 10:19 PM
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
