fuel pressure gauges
Old 05-28-2008, 09:19 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec TKO
Axle/Gears: 9 Bolt - 3:45
What is everybody using for fuel pressure gauges? Is Everyone using the accel unit? jegs sells one for the tpi and the lti. They look the same (minus the bracket) but the tpi is another 15 bucks more???? Figures.
Can you buy the hose/tube to the gauge on its own?
Old 05-29-2008, 02:42 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: fuel pressure gauges
Do you mean to test or a permanent install? I use the $12 Harbor Freight one for testing. Works great and comes with a lot of fittings for various cars.
Old 05-30-2008, 06:45 AM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
yeah just for testing, where did you get that one from?
Old 05-30-2008, 08:11 AM
jv9999's Avatar
Engine: 5.7L/350
harborfreight.com
Old 05-31-2008, 10:21 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
I should have figured it would be as easy as that! lol
Just so anybody wants to see the item...
http://www.harborfreight.com/cpi/cta...emnumber=92699
There must be something like that around here to buy.
So there is a fitting that will work for the TPI fuel rail in this package correct?
Old 05-31-2008, 11:38 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
I bought this one at my local Murray's several years ago for about 35. It is going for 26 at amazon.
http://www.amazon.com/Actron-CP7818-...2295024&sr=8-3
Infested
05-22-2018 11:56 PM
86IROC112
08-17-2015 02:00 PM
R3500
08-17-2015 12:16 PM
ChevyZ71
08-13-2015 07:30 AM
Kaweh
08-09-2015 02:54 PM
Quick Reply: fuel pressure gauges
