HELP! my car is on the side of the road!
Old Nov 14, 2001 | 10:34 PM
mynyka's Avatar
I was driving home from my lunch break and my tach fluttered a little when I stepped on it and when I took my foot off the gas the needle hit zero and the car will not start. Whats up. Could this be an Ignition module failure? I pulled a spark plug wire and put it on a strut tower bolt to see if I was getting a spark when I turned the engine over and NOTHING. Anyone ever heard of this.-88 formula 350.
Drew
Old Nov 14, 2001 | 10:39 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Could be any distributor part failure, even the coil. If you had a known good coil that would be the first thing i'd check (cuz i have a spare coil, lol)
Not much help, i know i'm tired, but someone should chime in with some help on testing procedures for the pick-up and module.
Old Nov 15, 2001 | 12:23 PM
leirch's Avatar
Ignition module sounds like a calprit, although, I had the SAME problem. Turns out that my MSD box was junk(don't know if that applies to you though). As always, if you do have an extra coil that is the first thing(easier to test a good coil than rip the distro out to find out that wasn't the problem).
Brendan
Old Nov 15, 2001 | 01:12 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Whenever you see the tach acting weird, it is 99% certain that it's the ignition module.
the other 1% is the ESC, coil or other unlikely part of the ignition system...
Old Nov 15, 2001 | 07:58 PM
mynyka's Avatar
Well, my guess was the ignition module too and I was right. I replaced it this morning and it fired right up. Thanks for all of your help guys.
Drew
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TEDSgrad
Mid-West Region
Aug 10, 2015 07:12 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
