how much out of my injectors?
Old Nov 16, 2001 | 08:50 PM
FstBrd6point3's Avatar
I have the stock 22# injectors in my 350 and I am wondering how much power I can push with them. . . I am most likely going to a 383 and I know I am going to need new injectors eventualy anyways, but can I live on them til the spring with just a AFPR? I am not going to put very many miles on it, and plan to baby the first couple thousand miles. . will I be ok with 22? thanx
Old Nov 16, 2001 | 09:10 PM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
ok, you should be ok with the 22's for a while but if your spending the money on a 383 you want the power to. Go with some 24's-30's and youll get some good flow. But around $250 a piece they will put a dent in your wallet
Old Nov 16, 2001 | 09:15 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Find a used set of LT1 24# injectors and have them cleaned and flowmatched. I picked my injectors up for $25 and had them cleaned and flowmatched by Cruizin Performance for $80. New screens and o-rings and they'll flow better than they did from the factory.
Old Nov 17, 2001 | 09:36 PM
PALM BEACH IROC-ER's Avatar
<font face="Verdana, Arial" size="2">Originally posted by FstBrd6point3:
I have the stock 22# injectors in my 350 and I am wondering how much power I can push with them. . . I am most likely going to a 383 and I know I am going to need new injectors eventualy anyways, but can I live on them til the spring with just a AFPR? I am not going to put very many miles on it, and plan to baby the first couple thousand miles. . will I be ok with 22? thanx</font>
You can consider a rising rate adjustable fuel pressure regulator RRAFPR from www.cartech.net/ for around $240. While this is costly, it has the potential for increasing most stock injectors flow as much as 40%, meaning a 5.7 injector can flow 51.6 lbs. per hour, generating over 100hp per. cyl. providing everything else is up to the task!
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
