knock sensor
Old May 31, 2008 | 04:57 PM
SCOTT OVERMANN's Avatar
knock sensor
what is the p/n for the knock sensor that I should be using with a tpi 383 with the ecm 1226870. thanks, Scott
Old Jun 1, 2008 | 09:46 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: knock sensor
My gues, would be to use the 350 KS to get better/intended results, since the 400 block is closer to the bore/spacing/wall thickness as a 350, rather than a 305...that'd be what I'd use.
Also, you have to make sure you run the right/correct EST module for the 350 KS.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
