tpi idle and maf help please!?
Old Jun 1, 2008 | 07:52 AM
jjskibbs's Avatar
Car: '89 IROC
Engine: 350 TPI 5.7L
Axle/Gears: axle?? got me.. 3.73:1 gears
hey guys, well my car is 89 iroc 305tpi. it runs gret, except the problem i have is when it warms to operating temp, it does not idle properly. it surges and will stall when i come to a stop. i have changed tps, iac, fuel filter. it has good fuel pressure about 42psi and drops to about 39 when running. i've cleaned the tb and iac port. wondering if anyone has any other ideas what could cause this issue??? the only code i had wass a 22 which hasn't come back yet. i did notice the maf screen torn. would that affect this??
Old Jun 1, 2008 | 10:10 AM
mouthforcombat's Avatar
Car: '86 Iroc Z
Re: tpi idle and maf help please!?
Usually, assuming there are no vacuum leaks and the timing is correct, cleaning the IAC port with some throttle body cleaner fixes this problem. Is your TPS adjusted correctly? As far as the torn screen on your MAF, it's not helping anything but if it's not throwing a code I think that would be okay for now.
Old Jun 1, 2008 | 09:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The screen isn't the issue, it's there to keep large debris from busting up your MAF wires.
If you suspect the MAF...just unplug it after it's warmed up and running rough, ECM will put it at some default setting...might not run the best, but won't chug/etc due the the MAF being unplugged.
Old Jun 3, 2008 | 03:32 PM
donaldw's Avatar
Car: 1988 pontiac trans am
Engine: 305 tpi
Axle/Gears: factory
my car does the ssame thing..at normal operating temps it wont idle at all...i have to keep my foot in it...i suspect its the iac motor...going to get a new one today and try it out
Old Jun 4, 2008 | 10:19 PM
jjskibbs's Avatar
Car: '89 IROC
i have tried unplugging the maf and usually it will stall out. also, to add... a few times it also will not start (i'm talking maybe once every 10 days or so) just cranks. i then spray ether into the tb and it fires right up and keeps running and will continue to restart after that. also, this issue happened right any ideas?
Logan Bryant
Aug 27, 2015 11:52 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
Sanjay
Aug 12, 2015 03:41 PM
