New to this TPI thing, please help!!
Old Nov 13, 2001 | 03:39 PM
draggin85's Avatar
Hey everyone. I have been running my 406 for almost three years now, and I think I'd like to make it a TPI motor. I have a complete TPI system from a 87 350 Camaro, and I'd like to throw it on my 406. I'm sure it's not that easy, though. So what all will I need to do? My motor is about 9.5:1 compression, and has a hydraulic Isky cam in it, I think it's a 292. The motor has 882 heads on it, also. It's making 300hp going through the LG4 manifolds (soon to be SLP and 3" all the way back) and stock exhaust (minus the cat) right now. What all will I need to do to make this work? the only fuelie car I have hands-on experience with in modding is a 5.0 Mustang (yeehaa) that I put a E303 cam in and ported the heads...for that I needed a new MAF sensor and everything worked fine...what can I expect???
Dave
Old Nov 13, 2001 | 06:59 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I really can't speak to how the torque band of the TPI will work with your heads and cam but to place the TPI on your engine you would need an O2 bung welded into your headers, a 5.7 knock sensor, standalone harness from someone like Painless Wiring and correct year ECM with a custom prom, a high pressure fuel pump in the tank. Thats just some of the stuff off the top of my head.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
[This message has been edited by Rob P (edited November 13, 2001).]
Old Nov 13, 2001 | 08:33 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
basically that and just switch to a mild camshaft. 292 is really large for a stock intake tpi.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 14, 2001 | 06:18 PM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
For what I have read, the stock tpi intake sistem was originally designed to meet the air requirements of a 305 engine, that's why the maximum hp is reached at apx 4400rpm, after that, the long tubes don't flow enough air to fill up the cylinders. Now with a big cubic inch motor like a 406, it will be like a person trying to run breathing trough a straw.
If you really want to go tpi, you best bet will be going with something with shorter runners like a miniram. Good luck.
Old Nov 16, 2001 | 11:32 PM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
dude,thats cool your trying to make a tpi.
but i dont want to hear about a 5.slow chumpstang
Old Nov 17, 2001 | 12:51 AM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
if you do some serious porting to the intake and siamesing (sp?) is a must! you should be ok with your cam if you siamiese. just look for the articles (search)
Andrew
Old Nov 17, 2001 | 02:01 AM
nblanchard's Avatar
Definately need to do some major porting of the intake and plenum, and get larger runners. Almost better to get the Super-ram plenum from Accel... its tough.. although TPI has the great low end torque... you'll starve your 400+ cid
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Best ET 14.559 @ 95.25MPH
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Nov 19, 2001 | 06:32 PM
BlazinOR's Avatar
I have a 406 TPI in my rather large K5 Blazer...........and it does starve, but not till well over 4500 rpm. Up till then it rocks......has 52mm throttle body, 24lb injectors, not sure on which heads or which cam but it moves out like right now. Painless wiring harness is what I used, hedman headers with an O2 bung welded in the collector, custom chip to get rid of VSS and VATS, etc. It is a SD setup too by the way.
Future mods...........hmm, not sure, but I keep reading this board every day and learn as I go. The guys here are fantastic.
'79K5 Blazer with 406TPI
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Bob88GTA
Aug 18, 2015 03:31 PM
Sanjay
Aug 12, 2015 03:41 PM
