failed emissions test again
Old Nov 18, 2001 | 12:00 PM
jeffzr600's Avatar
Okay a failed a IL emissions test by being over on Hydrocarbons during the cruising mode of the test, this is where the emissions testers accelerate to 55 to 60MPH and cruise for 30 seconds or so, passing is .80 I was at .89. So I started with the basics, new plugs, wires, cap and rotor. I went back for a retest and failed again, same stats basically.
This car is a 91 z28 (305 TPI) convertible with automatic 28K mileage, mostly stock. Injectors and fuel filter were replaced at about 22k, fuel pressure seems to be close to stock specs. Since the second test I have replaced the CTS since it seemed to be reading lower n resitance than a new one, i also will replace the oygen sensor. Anything else I should be looking at besides the CAT, is it possible the cat to be bad at 28K?
Old Nov 21, 2001 | 06:17 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
ttt
Old Nov 22, 2001 | 12:13 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Your cat converter is most likely the culprit. They get saturated, a new one usually will make you pass when you are that close.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC 3" Cat. back Exhaust
14.94-92.00 mph
SDPC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Hotrodboba400
Dec 10, 2019 07:07 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Veaceonee
Sep 29, 2016 08:15 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
