Injector harness routing ?
Old Nov 23, 2001 | 11:02 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Does each injector clip on the injector harness correspond to a specific injector? Or do you just have to get the sides right(drivers side, pass. side)?
Old Nov 23, 2001 | 11:59 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey,
Just hook the sides up correctly. Not that it
really matters, since its just TPI, not SPFI.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
Old Nov 24, 2001 | 12:40 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
That's what I thought. So as long as the sides are correct I'm good? There's no designated clip for the #1 cylinder and so on?
Old Nov 24, 2001 | 12:25 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Even the sides don't matter; on the TPI they're all connected inside the ECM and fire at the same time.
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
Brother Al
Oct 14, 2015 06:39 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Keith5
Aug 27, 2015 04:37 PM
