ignition cap with one corroded post causing problems?
Old Nov 24, 2001 | 12:10 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I changed my wires yesterday to try to fix a slightly bumpy idle I have on my 305 and noticed that the post for the #7 cylinder (driver side rear) was corroded really green (must be copper). I sanded it and put the new wires on.
I just repaced this cap and rotor this past august -- could this be causing some problems. at least this might be an indication of a bad spark to that cylinder right??
I will hook up the timing light to it to check it out today.
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts, PST front end poly stuff, Earl's hyperflex brake lines SSM SFCs, Bilsteins very trick homemade ramair, Accel 300+ ignition system. Ported plenum, intake and heads with 1.94I valves.
Planning: Heddman 1-5/8 longtubes, NOS 150 plate, replace the "peanut"! and Eibach Sportlines.
check it out at:
http://www.geocities.com/transam617
Old Nov 24, 2001 | 09:43 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i would have to say yes... a corroded post will cause problems. ie weak spark or no spark. i would take off the cap to check it and make sure there is no corrosion in there either. good luck
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
[This message has been edited by mystikkal_69 (edited November 24, 2001).]
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
Fronzizzle
Aug 17, 2015 02:52 PM
