cam lift
Old Nov 25, 2001 | 07:40 AM
SmokinZ28's Avatar
cam lift
How much lift can the stock 350 short block take with either TF 23d or AFR 195cc heads without hitting the pistons assuming everything else is set up correctly?
Old Nov 25, 2001 | 02:24 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Depends on valve timing. You could have .600" lift that doesn't hit, or .450" lift that does hit, depending on the timing of the vavle events relative to the crank.
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Jorlain
Oct 8, 2015 01:57 AM
abray1
Sep 10, 2015 04:53 PM
masonta
Sep 1, 2015 06:40 PM
