bosch type III 19lb or ford racing 19lb
Old Jun 7, 2008 | 04:16 PM
jjskibbs's Avatar
Car: '89 IROC
Engine: 350 TPI 5.7L
Axle/Gears: axle?? got me.. 3.73:1 gears
anyone know the difference if any. i'm getting mixed info off of ebay. some say they will work fine, others say they ave a higher flow rate and minor adjustments may be needed... isn't a 19lb injector the same flow rate??? a lot of people say the ford 19 works great (the bosch type III) but what about the ford racing 19lb???
thanks
also, i've read higher fuel pressure = better performance, so does the 19lb injector need to stay at the 43psi or can i increase it with an AFPR? if increased how would it affect?
1989 iroc 305tpi automatic
Old Jun 7, 2008 | 05:57 PM
jim91gta's Avatar
Car: 1991 GTA
Engine: 5.7
Re: bosch type III 19lb or ford racing 19lb
I found this link on this board, I just lost the thread it was posted in.
The thread was a ford injector thread.
Hope it helps
http://youtube.com/watch?v=Emnax2J4FX4
Old Jun 7, 2008 | 08:48 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
thanks
I HAVE BEEN PLAYING WITH THESE INJECTORS FOR OVER A YEAR NOW.. I MADE GOOD FRIENDS WITH JON AT FUEL INJECTOR CONNECTION. STD BOSCH III'S ARE SHORTER AND NEED A MODIFICATION TO GET UP IN THE RAIL. JON HAS FINALLY DONE THAT SO THEIR INJECTOR IS THE SAME HEIGHT AS THE STOCK WHEN INSTALLED. THE bOSCH III 19 IS RATED AT 37LBS. IT ACTUALLY FLOW A TAD UNDER 22 AT 43.5// WORKS GREAT IN MY 5.7.. THE REG. FORD MOTORSPORT FLOWS LESS. I ALSO THINK ITS A DENSO INJECTOR NOT BOSCH, BUT LOOKS IDENTICAL. THE 3 IS THE WAY TO GO. AND WITH THIS NEW MOUNTING THEY FIT GREAT. GIVE HIM A CALL. HE WILL STEER YOU RIGHT. GOOD LUCK
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
92-Formula
Dec 12, 2015 10:34 PM
Nervous2
Oct 8, 2015 10:53 PM
abray1
Sep 14, 2015 08:18 AM
ericjon262
Sep 11, 2015 06:07 PM
