how to tell 85-96, and 87+ TPI manifolds apart
Old Jun 9, 2008 | 02:46 AM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
I am looking @ purchasing a complete TPI system locally, unfortunately the seller only know that it was removed from an F-body. I understand that the only difference between 85-86 and 87+ was the center bolt angle, but i'm not sure i can visually judge that. Are there casting numbers on the base i could refer to? Or other obvious visual clues? Alternatively if anyone has close up pictures of the two different center bolt angles that would be helpful.
-Zander
Old Jun 9, 2008 | 02:56 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: how to tell 85-96, and 87+ TPI manifolds apart
On the 85 and 86 intakes, all intake bolts are drilled at the same angle. On the 87+, the middle four are drilled at a different angle. You should be able to tell just by comparing the inner four bolt holes to the others.
Hawkeye1980
Aug 31, 2015 07:09 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
