Should I port my 6085 heads?
Old Sep 22, 2001 | 03:54 PM
Mike89GTA's Avatar
I bought an engine for my car but I didn't have money for the entire intake, so it's kind of crippled right now. It's a 350 /w 6085 heads, LT4 Hot Cam, SLP 1 3/4 headers and a Superram base. I'm going to install the rest of the SR soon (wish I could go MR but emissions prevent it) but I'm not sure if while I have the intake apart I should just take the heads off an port them, since I can drive my other car in the mean time. Do you think it would be worth it? I wish I could have gotten the AFR 190's but money was an issue.
4 bolt 350, 10.4:1 Compression, Edelbrock Aluminum Heads 6085, LT4 Hot Cam /w 1.6 full rollers (Crane), Scat Crank, SLP 1 3/4" Headers, SLP Cold Air Intake, Crane AFPR, 48mm TB, ported plenum, stock runners, Accel Super Ram intake manifold, 95Z #24 injectors, stock fuel rails, T5 Tranny, 3.45s, 9 bolt rear, 4 wheel discs, BFG Comp T/As rear, SZ50s in front, Alston SFCs, ES Trans Mount, ES front A-arm bushings, ES front sway bar end links
Old Sep 22, 2001 | 08:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you know what you're doing, definitely port your heads and your intake.
Use this as a guide: http://www.sa-motorsports.com/
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 23, 2001 | 11:47 AM
Mike89GTA's Avatar
Should I just match the ports or can I "hog them out" so they flow as well as the AFR 190's?
Old Sep 23, 2001 | 08:14 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Actually you don't want to hog them out.
What you want is to smooth and blend.
Follow the guide lines in the above link.
That will give you most improvement, going to far on hogging out might ruin them.
Just remember-just because some is good doesn't meen a whole lot more is better.
HTH,
Don>>>
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Old Nov 29, 2001 | 02:07 PM
Mike89GTA's Avatar
ttt
Old Nov 29, 2001 | 04:28 PM
tpi_roc's Avatar
Yea which is why so many people make huge mistakes buying cams
I can't think of a single head ever made where porting to some degree didn't help
SO GET TO WORK!
Old Nov 29, 2001 | 08:12 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I would recommend not porting your Edelbrock heads. Perhaps port matching them to your intake, but chances are your intake ports are smaller than the cylinder heads. If I recall, Edelbrock heads are alreay sized to a felpro intake gasket.
They already come with stainless polished 2.02/1.60 valves, multi angle seat, etc. I also expect the shape of the port is optimal for the port size.
Unless you have access to a flow bench and know how to use it, I doubt there is much gain to be achieved, rather there is more to loose.
Perhaps a call to Edelbrock might offer some advice on what areas could be inproved to match your engine combination.
One word of advice. What looks good, does not always flow well.
Mark.
deracer
Apr 11, 2016 12:04 AM
italiano67
Aug 31, 2015 06:04 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
