89 formula 350, 350 vortec with tpi ,cold stumble,long cold crank,
Old Jun 11, 2008 | 04:41 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
anyone out there replace there l98 with a 350 vortec (L31)and use a edelbrock base .car ran fine before motor swap,motor also ran fine.i now have a long cold crank time and a cold stumble off the line with light throttle,goes away when warm,and i cant run the 8 degrees of base advance that i had before.when warm or ran for 2 minutes or more will start right up.stock tpi setup except the base,edelbrock headers,new dist,new fuel pump,new 02 sens,new maf,new cts,160 tstat,new tps,new cap rotor plugs wires,running 5 degrees of base advance,any more and it pings on the top end with 93 octane.iat sensor relocated off plenum.car runs great otherwise,just those 2 stupid issues,any help would be greatly appreciated.!!!!!!!!!!!!!!!!!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Sep 17, 2020 08:26 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
