Car immediately dies when I start it!
Old Nov 29, 2001 | 08:23 AM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
This feels wierd cause I haven't posted a question for some time now, but today I tried to start the car to go to class, and the thing would start and die instantly. It didn't even seem to respond to giving it a little gas when I started it or anything. I don't know where to look here, but I need to find a solution fast...I already missed a class today. Thanks
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, Edelbrock Headers, Catco Cat, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, MSD 6AL, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace
Old Nov 29, 2001 | 08:45 AM
BitchinCamaro's Avatar
HeHe, I am trying to hunt down a similar problem right now. Start by trying to find a loose sensor wire, or burnt plug wire. Are you getting any codes? Check to see if the distributor came loose (happened to my buddy) Good luck man, I feel your pain.
Old Nov 29, 2001 | 10:46 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Check the MAF ducting between the MAF and the TB, look for cracks/poor sealing. May also want to try disconnecting the electrical connector on the underside of the MAF and see if she fire up.
Old Nov 29, 2001 | 11:08 AM
ScreaminDeamin85Z's Avatar
if you can get it to run while holding the gas pedal, its your IAC. i had this problem once when i stopped to get gas, it would fire up but would die immediatly unless i had my foot on the gas.
Brandon
"ScreaminDeamin 360"
NOW RUNNING!!
1989 IROC 350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
T-56 ,McLeod clutch, LT4 PP
Newest Pictures
http://screamindeamin.cz28.com/newimages
http://ScreaminDeamin.cz28.com
Old Nov 29, 2001 | 11:46 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Could be your fuel pump. My just went like that a few weeks ago. It wouldnt respond to the gas pedal being pressed either. can you hear your fuel pump run at start up? Check your relays too and fuses.
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Serpentine Setup
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or http://members.cardomain.com/john87iroc
Old Nov 30, 2001 | 07:29 AM
IROCET's Avatar
Engine: 5.7L
Okay, I checked a few things out yesterday. I replaced the plug for the TPS, cause it had prong not making full contact. I also tested the fuel pressure, it stayed at 47 when the car was runnging and maybe dropped to 35-40 when it died. I also tried holding the gas pedal on the floor, and it had no effect. Any other suggestions? I didn't find any vacuum leaks in any well known areas, and all connections seem to be good. Thanks
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
