what kind of adapter do I need for fuel pressure gauge
Old Jun 12, 2008 | 07:19 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
What kind of adapter and hoses do I need in order to plug a fuel pressure gauge into the shrader valve on the fuel rail of my 91 305 TPI?
I looked at some fuel pressure gauges at summit, and was thinking of getting this thing:http://store.summitracing.com/partde...5&autoview=sku
Does anyone have better suggestions?
Old Jun 13, 2008 | 03:25 AM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
Re: what kind of adapter do I need for fuel pressure gauge
That gauge would be fine if left outs of the cabin. Otherwise use electric gauge if you want it inside.
Old Jun 13, 2008 | 06:56 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Don't buy that gage, had one and it would not keep a steady pressure reading. Bought a Autometer with a mounting pod and used SS braided line and fitting required by the gage. Picture of mounting location.
Old Jun 13, 2008 | 11:17 AM
Saculia's Avatar
Engine: 305TPI
djp87z28,
Do you have any problems with the gauge when it comes down to fuel leakage? I would be very much interested in installing a gauge permanently. Do you have a recommendation on what gauge to get and what size fittings and braided lines to get?
Old Jun 16, 2008 | 08:08 PM
DJP87Z28's Avatar
That is a Autometer gage and I have no problems with any leaks since the install in 2002. Sorry it been too long since I bought those items, I can not remember the sizes.
Everything was purchased at Sumitt.
Old Jul 14, 2008 | 11:22 AM
Chrisry1995's Avatar
Car: 89 Trans-Am
Engine: 5.7 TPI
I'm investigating the plumming too. As far as I can figure so far, Most gauges have 1/8-27 npt male threads and the fuel rail schrader valve is -4 an male. That's a flare fitting or AN standard developed by the Air Force/Navy. The Schrader valve unscrews from the rail and that's an even smaller thread/Male I'm guessing -2 AN but not sure. Basically a 1/8" npt female to -4 AN female would be needed, but so far Can't find one. Could get -4 AN female to 1/8 male and then get a 1/8 to 1/8 coupler. If I find out what the exact size of the small schrader valve end is I'll post that. Would be cool if we could get 1/8 female to -2 AN male and remove schrader. If someone knows, please tell or I'll reply if I find out myself. BTW if conecting to the top of schrader valve, don't forget to remove the valve. It's the same valve that's in a tire so the same valve removal tool will work also. Can get the tool at any bicycle or autoparts store. It just unscrews from the center.
Old Jul 28, 2008 | 10:04 AM
Car: 89 Trans-Am
Engine: 5.7 TPI
I was able to find a 1/8" 90 degree female to male. Then I found 1/8" female to -4an male adapter. Then I got a -4an female to female with swivel. So the gauge sits at a 90 degree and I can swivel it to face where I want. I got the parts at a local "mom & pop" hardware store in St.Clair Shores Mi. "Gilberts hardware". Love that place!! Only cost $8.00 at the most. And I can leave it on all the time with-out worring about the flex line or where to mount it. So you might be able to get your parts locally. Thats just my experience!!!
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
