Anyone degreed a cam with the stock timing chain on an L98?
Old Jun 12, 2008 | 07:36 PM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
Comp Cams is telling me that my stock L98 timing chain has advance ground into it, and that dot to dot isn't really a true zero degree install.
I find that a little odd, but it doesn't seem like it would be impossible. I don't have a degree wheel, so I don't have a way to verify one way or the other. Has anyone else ever tested a stock timing set?
Old Jun 12, 2008 | 07:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Anyone degreed a cam with the stock timing chain on an L98?
that is interesting and thats the first time i've heard it. My timing chain was so worn and stretched that i couldnt and wouldnt reuse it. I got a 9 way adjustable one much better
If it does have any advance ground in its probly only 2-4 degrees...but i highly doubt GM would do that. what comp is probly saying is factory tolerances allows several degrees off true zero to be used. SO a factory straight up degree mark may actually be anywhere from 3 degrees retarded to 3-4 degrees advanced. I would think tolerances were more along the lines of +- 2 degrees but you never know
Then again, i've read threads where aftermarket timing chains, even those by comp cams have been off a few degrees
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
MY87LT
Aug 17, 2015 08:43 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
