LT1 conversion
Old Dec 1, 2001 | 05:37 PM
84LS creeper's Avatar
Car: 96 Chevy Silverado
LT1 conversion
I have an 84 Monte LS, I am presently building a 355 with 200 / 700 r4 tranny. My question is this, I just purchased an 95 LT1 intake system, I would like to know what I will be needing to complete this retro? I have access to an complete harness from an 91 Camaro. I also can get an TPI ECM from a 88 Iroc. The engine block is out of an 72 Nova. The intake unit is coming with all the ssensors except fuel rails, injectors are there. I do plan on replaing sensors as necessary. All and any advice appreciated. Thanks DL
Old Dec 1, 2001 | 05:52 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I'm in the middle of the conversion right now, using a '95 intake also. Right now, I'd recommend studying John Millican's site: http://members.home.net/millicanga/
Some problems I've run into are here:
https://www.thirdgen.org/messgboard/...ML/005519.html
I've posted preliminary pics at my site until I can do a full write-up. I also have all the plates and templates drawn in AutoCad (not posted).
Search www.sethirdgen.org for more info, also.
One thing I haven't mentioned is that I've had a hard time with the intake mounting holes. Possibly due to the heads having been milled, although my TPI intake was not a problem. I've had to slot all of them to get them to fit. It's very important that the corner pairs of holes are perpendicular to the mounting plane of the intake. Had I to do it again, I would have filled ALL of the holes, including the outside ones. Then drilled them correctly.
Also, check with the ECM & PROM forums, because the '88 ECM will not work with the '91 harness without work. ('88 is a MAF system, '91 is Speed Density).
Email me if you have other ?s. Or look here for my updates. Check with John, too. (He's the man)
Bob '89 Ram Air Formula 350
And until that time when death won't wait, let each man rage against his fate. (O'neill)
My car's homepage
Reader's Ride
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
