cold air intake under canister??
Old Nov 30, 2001 | 11:00 PM
breathment's Avatar
ok, while i was under my car changing the spark plugs, i noticed that the thing which the charcoal canister is bolted to (which is right next to the air filter) is able to be seen from the bottom of the car, and it looks like i could relocated the canister a little more towards the side of the car, take off the panel that the canister mounts to, and have a PERRfect spot to cut and mount a filer under the car for a really good cold air intake, but i haven't taken a good look at it yet, anyone know anything about this spot? im gonna look more tomorrow and see if i can make somethign with it.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Dec 1, 2001 | 05:41 PM
breathment's Avatar
anyone, before i take all the crap off and jack up the car?
- David
Old Dec 1, 2001 | 09:25 PM
Roshambo's Avatar
It can be done, a guy in the Cascade crew used a K&N cone filter, and then sorta copied the CAI kits from the 5.0s with the scoop. Pretty slick setup, and you shouldnt have to worry about water if you do it right.
-Roshambo
Joe
1988 Pontiac Trans Am WS6 - 305 TPI, 700R4, 3.23 Posi, Digital Dash, Leather Seats, Maui Blue with Silver GFX, T-tops, Tinted Glass, Gutted MAF, TB Coolant Bypass, K&N Cone Filter, 3" Summit Exhaust Cut-Out, 3" exhaust from Y-pipe back, MSD Super Coil, Accel 8mm wires, L98 Aluminum Heads, Ported and Polished Plenum, Siamesed Intake, Aluminum Driveshaft, Edelbrock 3 point Strut Tower Brace.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
