AFPR - location?
AFPR - location?
Sorry if this seems lame, but my TPI406 has the stock FPR and I have no clue where these adjustable FPR's go. Do they simply replace the stock one? How difficult to swap in the new one? How much $$ for an AFPR?
Thanks in advance.
'79K5 Blazer with 406TPI
Thanks in advance.
Yes you simply replace the stock one (passenger side underneith the plenum towards the rear of the fuel rail). I made and recommend making your own, its super simple and beats blowing $50 on one that somebody else made. Just braze a low pro nut into the center of the cap, and put a quarter under the cap and a bolt into it (make sure its air tight because of vacum) and you're good to go.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hi,
Your gonna need a T10 security bit. The stock cap bolts on the regulator have the little posts in them, like cable box's.
Whats the quarter for?? I welded a nut on the bottom of my bolt, so it would center better.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs F/P gauge, A/F ratio gauge, MSD 6AL, MSD Redline selector.
http://www.joesperformance.com
-- Joe
bigjay89gta
Oct 15, 2015 08:04 AM
2012sergen11
Oct 13, 2015 07:38 PM
