MAF Sensor Question???
Old Dec 1, 2001 | 02:23 PM
CloudZStrife's Avatar
If the MAF sensor is'nt working properly it is'nt life threatening to my engine is it, I would just expect to get a little bit of bad gas mileage right, any other things people have experienced?...
87 IROC-Z, 3.23 posi, new 305 TPI, and soon to get new trans and world torquer 305 heads
Old Dec 1, 2001 | 02:43 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by CloudZStrife:
</font>
For how long?.
You'll be risking hurting an exhaust valve, catalytic converter, like you said bad mileage.
If your running with a SES light on, then you might shorten the ring life, from being too rich.
Anyway you cut it your not doing the engine any good.
Old Dec 1, 2001 | 04:06 PM
WEll I'm not driving it right now It's being stored but when I put it on the road I'll prolly be drivin a little with the maf sensor not hooked up because there's somethin wrong with it...maybe for like a week or 2, prolly totalled up about 200 miles total.. Should I just leave it hooked up until i get a new one
Old Dec 1, 2001 | 05:26 PM
IROCKER's Avatar
I'm surprised it even runs without it hooked up...My MAF went south early in the summer and the car wouldn't rev above 3200RPM and keep stalling.
I would definately save your pennies and get it replaced ASAP...look for a company that sells rebuilt ones. I got a new rebuilt one through my mechanic at a third of the cost of the dealer and a longer warrenty than GM offers.
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for front and rear LCAs and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, 3" Mandrel-bent pipes, Flowmaster muffler, Corvette Servo, TransGo Shift Kit, Corvette 2000 Stall, TruCool LPD tranny cooler, T-tops.
2001 Sunfire GT
2.4L, 5-speed, K&N cone filter, interior detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
Web: http://www.angelfire.com/on3/whitelightening
Old Dec 1, 2001 | 05:27 PM
hummm I've been reading about that Wells MAF unit anyone have anyluck with it. I guess Pep Bys sells it or somethin I'll be sure to change the MAF power, and burnoff too
Old Dec 3, 2001 | 06:15 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Autozone sells MAF's for like 50.00.
I see them in the junkyard all the time. 10-20.00 used.
Finding a MAF isn't rocket science.
Would you drive around with a broken harmonic balancer? than don't drive around with a bad maf.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs F/P gauge, A/F ratio gauge, MSD 6AL, MSD Redline selector.
http://www.joesperformance.com
Old Dec 3, 2001 | 12:59 PM
Good Ideas guys thanx
chazman
Aug 28, 2018 03:25 PM
Logan Bryant
Aug 27, 2015 11:52 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
