can I run a xe268h with my tpi?
Old Jun 15, 2008 | 01:30 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I just got a killer deal on a smallblock 355......... My car has a tpi 305 in it now........ I just boght a 355 with no miles,flat top forged pistons, and a brand new xe268h comp cam/lifter combo setup...... its a flat tappet hydraulic cam 224/230...477/.480 with 110 lobe seperation. Can I still run my tpi with this cam if I get a 350 memcal for my ecu,knock sensor, and 24lbs injectors?
Old Jun 15, 2008 | 08:50 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
Re: can I run a xe268h with my tpi?
the computer aint gonna like it but i am sure it would run just not very well. and would require alot more tuning than a wider lsa cam to get it dialed in.
Old Jun 15, 2008 | 09:00 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Im trying to figure out if I should switch to a vac secondary elec choke demon and ditch the tpi, with ecu programming , new chip, new injectors, knock sensor, and still nothing above 5k rpm thats alot of money. Do you think itll be cheaper to switch to carb. What do you think
Old Jun 16, 2008 | 05:35 PM
DerekZ28's Avatar
Car: 1989 Formula 350
Transmission: 700R4 Auto
Axle/Gears: 3.27 Borg Warner
I bought a big xtreme energy cam for my L98. 110 LSA, TPI doesnt like it.
it wont be cheap at all and you might as well ditch the TPI and get a stealth ram. I already bought a HSR along with the cam. but you might as well get another car for driving to work because gas mileage will go down the drain.
tpi doesnt make pwr past 4800 RPM and my cam is designed for something that does.... so HSR is the way to go... BTW you need massive computer mods.... youll run too rich to compensate for the valves being open for too long........ get your ECU burned for the cam and get a different intake.... carb/hsr anything but TPI....
Old Jun 17, 2008 | 12:05 AM
Car: 88 IROC
i changed over to a carb in my iroc some time ago, and i had that exact cam you are running in a basically stock motor. it ran good i ran 13's in the quarter at 104, if i could have got the car to hook up i would have been in the low thirteens if not high 12's. but i was not getting good gas mileage at all. i just changed back to tpi and i think i am going to like it alot more. it is a 305 with a l98 cam and a tpi with slp runners. i am hoping to be running in the 14.8 range but we will see. i know i will be getting alot better gas mileage than i was before with that stupid 650 double pumper i put on there.
Old Jun 17, 2008 | 08:06 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Im no racer, so mpg (as most of us at $4.30 a gallon) is important. Its not a daily driver, when my truck isnt broke, but I would really like to keep tpi for now and hsr later. Does anyone make custom chips for $200-250. Not a "performance chip" but custom burnt for my cam.
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
