Nitrous w/ Stock TPI set-up
Old Nov 30, 2001 | 01:01 AM
Josh'sFORMULA's Avatar
Another newbie here, I hear you guys complaining about the air intake volume of the stock TPI, but could a fogger system be utilized with this setup, with an adequate fuel pump? Maybe I should ask this question.
How do I produce big numbers 400rwhp looking stock? Money isnt a problem but the formula for doing so is. 355ci or 383ci I want the bottle for sure but internally I need it to hold together PLease HELP Keep in mind MONEYisno problem just help get me there please
Old Dec 1, 2001 | 12:04 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You say money is no problem. How much money?
400HP easy.
350 4 bolt 1 peice motor
Machine mains for 383 stroker
Sportsman-II, or Trick-Flow heads
(if your going turbo go with the 72cc
chambers, if not, go with 64cc)
forged flat-top pistons
400 crank, keep the 5.7" rods, but
you should get forged 5.7". DONT use
6 inch rods.
You can use any cam you want really, but
the duration should be around 223/236 -
230/240 (at .50). Any lower or higher and it won't work well. That duration is for a
2700-6,000 RPM motor. which is about what you
want.
If you go 383 you'll need to balance the motor, if you go with a 355, you can get
"factory balance" rods, crank, and pistons.
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs F/P gauge, A/F ratio gauge, MSD 6AL, MSD Redline selector.
http://www.joesperformance.com
Old Dec 2, 2001 | 02:26 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I would bet I can put down 400 rwhp
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Dec 3, 2001 | 07:12 PM
nblanchard's Avatar
I used DeskTop dyno to set up a engine combo and theoretically got 450+ flywheel power... But It needed the Accel Super-ram system.
If money is no worry.... well... get a forged crank, forged rods, forged domed pistons, ARP fasteners all around.. this will ensure that the bottom end will hold.
The rest depends on where you want your power... Look through the cams from different companies... I was gonna go with CompCams. Edelbrock Performer heads are a nice purchase. Get the whole Lingenfelter/Accel EFI System.. this way you can program your computer with a laptop and get precise tuning. You said money wasn't an issue... then you should be able to get 400rwhp EASY!!!
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Best ET 14.559 @ 95.25MPH
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
West Coast GTA Man
Jun 19, 2001 12:03 PM
Timmys88Z
May 9, 2001 10:26 AM
StCr19
Jan 7, 2001 07:23 PM
Brandog87GTA
Nov 15, 2000 05:08 PM
Brandog87GTA
Carburetors
Nov 15, 2000 12:28 PM
