Timing Problems
Old Dec 2, 2001 | 02:19 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Timing Problems
I have a big problem with my timing I set it to where it runs the best the timing mark is straight up though way past the timing tab (advanced)when I brought it down to factory specs it sounded good and my exhuast leaks became more noticable. Ok I though it should run better seeing that my timing is correct. WRONG runs like Sh*t and backfires a couple times absolutly has NO power. so I turned the timing up (to where it was) and called it a day. I was talking to a "genius" about it and he said a vaucum leak would make it run like crap when timing is set. "It effects the injectors on these fuel injected cars" but him being an old school carb guy i decided to push it back in my mind and ask some others. I have replace my harmonic balancer but i installed it properly with the woodruff key (so there is only one way for it to fit)has anyone had this kind of situation??
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Dec 2, 2001 | 09:05 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by Chris Etemadi:
</font>
possible you ought a balancer for a 305. the timing mark is at 12 o'clock. the 350 is about 1 o'clock.
mrrjjdh03@aol.com moderator at www.fl-thirdgen.org
[This message has been edited by mrr23 (edited December 02, 2001).]
Old Dec 2, 2001 | 02:42 PM
HighHopes85's Avatar
If you didn't bypass the EST, then timing will be base timing + chip timing. Chip timing depends on a few things, but it could be in the ballpark of where your mark was. You are looking at an advance from 10-30 degrees added by the computer.
There are no less than 4 factory balancers for small blocks. That is the other possibility. -Matt-
Old Dec 2, 2001 | 03:54 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
hey chris,
if you didn't bypass your electronic spark timing (est) the brown wire with a white line in it, then it won't be correct.
also a vaccume leak won't affect (effect?) your timing since we have electronic advance distributors not vaccume advance it will just let your car idle higher.
if you want you can give me a call and i can come by and look at it later today (sunday) after church or i can look at it tomorrow (monday) sometime.
Andrew
Old Dec 2, 2001 | 08:53 PM
Jim's Avatar
Jim
Car: 85 Camaro
I am having the exact same problem. It started when my harmonic balancer seperated and I replaced it with a Fluidampere.
The thing that really toasts my cookies is that when I rebuilt the engine last spring the balancer lined up perfectly with the zero mark when I had the number one piston all the way up. i checked this, re-checked it and had several other people check it out.
Put the engine back together and put it back in the car, started it up and whamo the damn thing still goes to the 12 o'clock position. I can't figure it out but the car runs perfectly???
Old Dec 2, 2001 | 09:14 PM
Car: 1991 Z28
Im not an idiot, (not completely) I have had my car since I was 15 yes i know your supossed to disconnect the EST connector.
91 Z28 5.7l Camaro
more to come....
My 91 Z28
Old Dec 3, 2001 | 07:26 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Whats your timing advance to with the
Est wire connected? I'm curious if your computer is advancing or whatnot.
The symptoms you speak of sounds like retarded timing, or way-to-high-for-your-application gas.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs F/P gauge, A/F ratio gauge, MSD 6AL, MSD Redline selector.
http://www.joesperformance.com
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
