Distributor internal oil leak - watch out
Old Jun 15, 2008 | 10:22 PM
MedVader's Avatar
Car: 90 Formula hardtop
Engine: 5.0 TPI
I bought an ebay distributor last winter. I installed it recently and discovered the damn thing isn't properly sealed from oil pushing up the shaft and then leaking though the vent screen.
Skip White. billet distributor. Looks great. $57. POS
I had to put the cruddy 130K mile distributor to get running without an oil leak.
So if you have an oil leak that's driving you nuts from the backside of the engine, before you yank that manifold off(like I did) pull off the distributor cap and if it's coated with oil inside, there's your leak.
Old Jun 16, 2008 | 12:13 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Re: Distributor internal oil leak - watch out
never would have thought to look there for an oil leak.
some oil in there might have saved my pickup coil from rusting itself int 3 pieces
Old Jun 16, 2008 | 12:31 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
gm has a updated shaft because of that problem
Old Jun 16, 2008 | 02:57 PM
MedVader's Avatar
Engine: 5.0 TPI
Yeah that would be good if that's all it did. But when that seal isn't working right, it's enough to leave a puddle under your car everytime. Looks just like a manifold RTV leak.
xxx3man`
Sep 23, 2015 10:37 PM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
drathaar907
Aug 6, 2015 04:20 PM
