1.5 or 1.6?
Old Nov 29, 2001 | 10:23 PM
DFI79MC's Avatar
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
1.5 or 1.6?
I will be swapping my ED 6085's on my motor pretty quick and I was wondering if I should get 1.5 or 1.6 roller rockers. The combo I have is an Accel base, mildy opened SLP runners, TPIS AFPR, TPIS 52MM TB, ported and siamesed plenum, Comp roller cam with .510 lift, 210 220 duration, 114 LSA, gutted maf, big K&N. The tranny in the car is a 2004-R with a 2600 RPM stall, and the car has a 3.73 rear gear. What do you all think? Responses are greatly appreciated. Thanks
1979 Monte. 88 TPI, .30 over 89 350. SLP, Accel, TPIS, Comp Cams just to name a few. : http://www.monte-list.nu/html/images/jeremy_polar/
Old Nov 30, 2001 | 02:38 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Get 1.6. Just make sure yuo check all he clearances before you start he car.
Old Dec 1, 2001 | 12:54 AM
airdeano's Avatar
Most unported heads approach 85 or 95 % of peak flow at .400 to .450 lift and do not need or want a maximum valve lift over .540 to.555. Often a low cam lift with 1.6 ratio rockers is very helpful on the intake side as long as lift is kept to about .550. Exhaust is less critical with 1.5 or 1.55 being the most popular.
airdeano
Old Dec 4, 2001 | 09:40 PM
pico87iroc's Avatar
how would the 1.6s be with the stock cam
87 IROC-Z 305tpi
still $h!ten on
rustangs
Old Dec 5, 2001 | 01:14 AM
rezinn's Avatar
1.6s are a good idea on a stock cam, but you may need longer pushrods.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
