Measuring a Cam Question????
Old Jun 16, 2008 | 10:39 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
I took the camshaft out of my car last nite and now wanted to measure the lift of it.... I know, I probably should have left it in... But I have a funny feeling that something wasn't right!!!! (Poor Performance...)
The measurement from base-circle to Nose was the same as my LPE Cam so I know that I'm doing something wrong and there's more to it....
Is there a simple way of doing it without putting the cam and timing chain back on???
I have a micrometer, and a deflection gauge with magnetic base...and a degree wheel
But was hoping that I could figure out my lift without re-assembling everything!!!!
Please Help
Old Jun 17, 2008 | 10:57 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Re: Measuring a Cam Question????
I think that I figured it out.......
I measured the base circle by taking my micrometer to the horizontal cross section to find out how wide it was , then measured the lobe top to bottom. When I was done I subtracted the base circle measurement from the lobe nose measurement and Whalla. I had my cam lift....
I cross referenced my technique on the LPE cam and it works...........
Old Jun 17, 2008 | 08:49 PM
Damon's Avatar
That's a valid method until you get into some very large cams with very high durations. I've measured many cams using exactly the method you describe and it's always given me "sane" results, so I trust it as generally reliable
Old Jun 17, 2008 | 09:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
that will give you a ball park figure
Old Jun 17, 2008 | 10:05 PM
skinny z's Avatar
You could place the cam up on a couple of v-blocks (with a little lube). Set up the dial indicator/deflection gauge and spin the cam for accurate results.
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
