92 tpi harness in a 88 ?????
Old Jun 17, 2008 | 05:36 PM
tazz08's Avatar
Hello
I have a 88 trans am had a tpi 350 witch the motor and harness and ecm is gon and I have a motor and harness ans ecm out of a 92 z28 and I notesta the hareness was missing the wiper motor harness and iy had a brake senser plug.
Is there a way to make the harness work or shuld I just get a 88 hares and ecm?
Old Jun 17, 2008 | 09:15 PM
wannabe92z's Avatar
Re: 92 tpi harness in a 88 ?????
I did a similar changeover when I installed a 92 speed density engine and tranny in my brothers 88. It is really not that hard if you repin the 92 harness at the c100 connector to match the firewall side of the main harness plug. He's been tugging along for a year now with no glitches or issues. It took longer to hunt down the wiring diagrams, but this board and EBay are a huge help. We got the 88 factory service and snooped around the net to find the 92 harness wiring diagram. I promise you that it is nowhere near as difficult as it may seem, you just pull the white plastic clip retainers and start moving them around one by one. It took every bit of about 3 hours. I wish we would have marked what we did, so I could easily tell you which wires needed to be moved, but I will tell you that quite a few of them didn't have to be moved. Hope this helps. If you need a copy of that 92 diagram, let me know. I should have it stored on my computer somewhere. Email me at wannabe92z@yahoo.com if you need it.
Old Feb 21, 2009 | 08:07 AM
redltcamaro's Avatar
Car: 1987 LT Camaro
Engine: Empty at the moment
Transmission: thats out too
Axle/Gears: 4.11
i am kind of looking for the same thing i have an 87 v6 and i am swapping a 92 tpi into my camaro. i have been looking around for a while.
this is the c100 connector for the 92
http://www.austinthirdgen.org/mkport..._1992_C100.gif
i can not find the one for your 88 there is an 87 and an 89 on the site if you would like to look at the site they are all listed at the bottom austinthirdgen.org
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
IBrockZ
Aug 20, 2015 12:20 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
